Evironment detail is: Clients (Windows 7) > Big-IP APM v11.4.1 (Load balancer) > SharePoint Server 2013 (Windows Server 2012)
I have deployed a SharePoint app on SharePoint Server. Clients can access SharePoint app properly with Google Chrome but fail on IE11. Noted that AJAX calls are aborted. But IE11 works well when bypassed the load balancer (F5). I have observed that during navigating the app, Google Chrome does not require re-authentication with load balancer but IE11 requires and prompt Windows Authentication screen again and again.
As per our understanding could be possibility of following reasons: 1. Google Chrome intelligently persists authentication token at its end and present to F5 whereas IE11 does not. 2. F5 APM has a policy of re-authentication in multi/cross domain communication which IE11 follows. 3. Need to define static SPNs for domains. 4. F5 APM session holds authentication token but not send to SharePoint in case of IE11.
So let us know what could be the possible reason and how to handle it?
Regards, Jhan Zaib
