Why stop at 3 when you can go to 4? Over the past few posts on this ever-expanding topic, we’ve discussed using ADFS to provide single sign-on access to Office 365. But what about single sign-out?
A customer turned me onto Tristan Watkins’ blog post that discusses the challenges of single sign-out for browser-based, (WS-Federation) applications when fronting ADFS with a reverse-proxy. It’s a great blog post and covers the topic quite well so I won’t bother re-hashing it here. However, I would definitely recommend reading his post if you want a deeper dive. Here’s the sign-out process:
1. User selects ‘Sign Out’ or ‘Sign in as Different User’, (if using SharePoint Online);
2. The user is signed out of the application;
3. The user is redirected to the ADFS sign out page; and
4. The user is redirected back to the Microsoft Federation Gateway and the user’s tokens are invalidated.
In a nutshell, claims-unaware proxies, (Microsoft ISA and TMG servers for example) are unable to determine when this process has occurred and subsequently the proxy session remains active. This in turn will allow access to ADFS, (and subsequently Office 365) without be prompted for new credentials, (not good!). Here’s where I come clean with you dear readers. While the F5 Big-IP with APM is a recognized replacement for the AD FS 2.0 Federation Server Proxy this particular topic was not even on my radar.
But now that it is……
Single Sign-Out with Access Policy Manager
You’ll may have noticed that although the Big-IP with APM is a claims-unaware proxy I did not include it in the list above. Why you ask? Well, although the Big-IP is currently “claims-unaware”, it certainly is “aware” of traffic that passes through. With the ability to analyze traffic as it flows from both the client and the server side, the Big-IP can look for triggers and act upon them. In the case of the ADFS sign-out process, we’ll use the MSISSignOut cookie as our trigger to terminate the proxy session accordingly.
During the WS-Federation sign out process, (used by browser-based applications) the MSISSignOut cookie is cleared out by the ADFS server, (refer to the HttpWatch example below). Once this has been completed, we need to terminate the proxy session. Fortunately, there’s an iRule for that.
The iRule below analyzes the HTTP response back from the ADFS server and keys off of the MSISSignOut cookie. If the cookie’s value has been cleared, the APM session will be terminated. To allow for a clean sign-out process with the Microsoft Federation Gateway, the APM session termination is delayed long enough for the ADFS server to respond. Now, APM’s termination can act in concert with the ADFS sign-out process.
<span id="lnum1" style="color: rgb(96, 96, 96);"> 1:</span> when HTTP_RESPONSE {
<span id="lnum2" style="color: rgb(96, 96, 96);"> 2:</span> # Review server-side responses <span style="color: rgb(0, 0, 255);">for</span> reset of WS-Federation sign-<span style="color: rgb(0, 0, 255);">out</span> cookie - MSISSignOut.
<span id="lnum3" style="color: rgb(96, 96, 96);"> 3:</span> # If found assign ADFS sign-<span style="color: rgb(0, 0, 255);">out</span> session variable and close HTTP connection
<span id="lnum4" style="color: rgb(96, 96, 96);"> 4:</span> <span style="color: rgb(0, 0, 255);">if</span> {[HTTP::header <span style="color: rgb(0, 96, 128);">"Set-Cookie"</span>] contains <span style="color: rgb(0, 96, 128);">"MSISSignOut=;"</span>} {
<span id="lnum5" style="color: rgb(96, 96, 96);"> 5:</span> ACCESS::session data set session.user.adfssignout 1
<span id="lnum6" style="color: rgb(96, 96, 96);"> 6:</span> HTTP::close
<span id="lnum7" style="color: rgb(96, 96, 96);"> 7:</span> }
<span id="lnum8" style="color: rgb(96, 96, 96);"> 8:</span> }
<span id="lnum9" style="color: rgb(96, 96, 96);"> 9:</span>
<span id="lnum10" style="color: rgb(96, 96, 96);"> 10:</span> when CLIENT_CLOSED {
<span id="lnum11" style="color: rgb(96, 96, 96);"> 11:</span> # Remove APM session <span style="color: rgb(0, 0, 255);">if</span> ADFS sign-<span style="color: rgb(0, 0, 255);">out</span> variable exists
<span id="lnum12" style="color: rgb(96, 96, 96);"> 12:</span> <span style="color: rgb(0, 0, 255);">if</span> {[ACCESS::session data get session.user.adfssignout] eq 1} {
<span id="lnum13" style="color: rgb(96, 96, 96);"> 13:</span> after 5000
<span id="lnum14" style="color: rgb(96, 96, 96);"> 14:</span> ACCESS::session remove
<span id="lnum15" style="color: rgb(96, 96, 96);"> 15:</span> }
<span id="lnum16" style="color: rgb(96, 96, 96);"> 16:</span> }
What? Another iRule? Actually, the above snippet can be combined with the iRule we implemented in Part 3 creating a single iRule addressing all the ADFS/Office 365 scenarios.
<span id="lnum1" style="color: rgb(96, 96, 96);"> 1:</span> when HTTP_REQUEST {
<span id="lnum2" style="color: rgb(96, 96, 96);"> 2:</span> # For external Lync client access all external requests to the
<span id="lnum3" style="color: rgb(96, 96, 96);"> 3:</span> # /trust/mex URL must be routed to /trust/proxymex. Analyze and modify the URI
<span id="lnum4" style="color: rgb(96, 96, 96);"> 4:</span> # <span style="color: rgb(0, 0, 255);">where</span> appropriate
<span id="lnum5" style="color: rgb(96, 96, 96);"> 5:</span> HTTP::uri [<span style="color: rgb(0, 0, 255);">string</span> map {/trust/mex /trust/proxymex} [HTTP::uri]]
<span id="lnum7" style="color: rgb(96, 96, 96);"> 7:</span> # Analyze the HTTP request and disable access policy enforcement WS-Trust calls
<span id="lnum8" style="color: rgb(96, 96, 96);"> 8:</span> <span style="color: rgb(0, 0, 255);">if</span> {[HTTP::uri] contains <span style="color: rgb(0, 96, 128);">"/adfs/services/trust"</span>} {
<span id="lnum9" style="color: rgb(96, 96, 96);"> 9:</span> ACCESS::disable
<span id="lnum10" style="color: rgb(96, 96, 96);"> 10:</span> }
<span id="lnum12" style="color: rgb(96, 96, 96);"> 12:</span> # OPTIONAL ---- To allow publishing of the federation service metadata
<span id="lnum13" style="color: rgb(96, 96, 96);"> 13:</span> <span style="color: rgb(0, 0, 255);">if</span> {[HTTP::uri] ends_with <span style="color: rgb(0, 96, 128);">"FederationMetadata/2007-06/FederationMetadata.xml"</span>} {
<span id="lnum14" style="color: rgb(96, 96, 96);"> 14:</span> ACCESS::disable
<span id="lnum17" style="color: rgb(96, 96, 96);"> 17:</span>
<span id="lnum18" style="color: rgb(96, 96, 96);"> 18:</span> when HTTP_RESPONSE {
<span id="lnum19" style="color: rgb(96, 96, 96);"> 19:</span> # Review serverside responses <span style="color: rgb(0, 0, 255);">for</span> reset of WS-Federation sign-<span style="color: rgb(0, 0, 255);">out</span> cookie - MSISSignOut.
<span id="lnum20" style="color: rgb(96, 96, 96);"> 20:</span> # If found assign ADFS sign-<span style="color: rgb(0, 0, 255);">out</span> session variable and close HTTP connection
<span id="lnum21" style="color: rgb(96, 96, 96);"> 21:</span> <span style="color: rgb(0, 0, 255);">if</span> {[HTTP::header <span style="color: rgb(0, 96, 128);">"Set-Cookie"</span>] contains <span style="color: rgb(0, 96, 128);">"MSISSignOut=;"</span>} {
<span id="lnum22" style="color: rgb(96, 96, 96);"> 22:</span> ACCESS::session data set session.user.adfssignout 1
<span id="lnum23" style="color: rgb(96, 96, 96);"> 23:</span> HTTP::close
<span id="lnum24" style="color: rgb(96, 96, 96);"> 24:</span> }
<span id="lnum25" style="color: rgb(96, 96, 96);"> 25:</span> }
<span id="lnum26" style="color: rgb(96, 96, 96);"> 26:</span>
<span id="lnum27" style="color: rgb(96, 96, 96);"> 27:</span> when CLIENT_CLOSED {
<span id="lnum28" style="color: rgb(96, 96, 96);"> 28:</span> # Remove APM session <span style="color: rgb(0, 0, 255);">if</span> ADFS sign-<span style="color: rgb(0, 0, 255);">out</span> variable exists
<span id="lnum29" style="color: rgb(96, 96, 96);"> 29:</span> <span style="color: rgb(0, 0, 255);">if</span> {[ACCESS::session data get session.user.adfssignout] eq 1} {
<span id="lnum30" style="color: rgb(96, 96, 96);"> 30:</span> after 5000
<span id="lnum31" style="color: rgb(96, 96, 96);"> 31:</span> ACCESS::session remove
<span id="lnum32" style="color: rgb(96, 96, 96);"> 32:</span> }
<span id="lnum33" style="color: rgb(96, 96, 96);"> 33:</span> }
Gotta love them iRules! That’s all for now.
Additional Links:
Big-IP and ADFS Part 1 – “Load balancing the ADFS Farm”
Big-IP and ADFS Part 2 – “APM–An Alternative to the ADFS Proxy”
Big-IP and ADFS Part 3 – “ADFS, APM, and the Office 365 Thick Clients”
BIG-IP Access Policy Manager (APM) Wiki Home - DevCentral Wiki
AD FS 2.0 - Interoperability with Non-Microsoft Products
MS TechNet - AD FS: How to Invoke a WS-Federation Sign-Out
Tristan Watkins - Office 365 Single Sign Out with ISA or TMG as the ADFS Proxy
Technorati Tags: load balancer,ADFS,Office365,active directory,F5,federation,exchange,microsoft,network,blog,APM,LTM,Coward,SSO,single sign-on,single sign-out
