Actually, I have one 2 VS. One listening on port 80 with an LTM policy to redirect the traffic on the second VS listening on port 443. I’m looking for a solution to prevent the F5 to answer on port 80 to tcp connexion coming from a scan tool.
You can attach iRule to HTTP VIP to reject the traffic coming from the scanning tool.
Using data-group
when CLIENT_ACCEPTED {
if { [class match [IP::client_addr] equals scanner_ip] } {
reject
return
Using IP-address within the iRule
if { [IP::addr [IP::client_addr] equals <scannerip> ] } {
reject
return
You can redirect the request from port 80 to port 443.
( HTTP::redirect …)
This way do not prevent the F5 to answer on port scanning
In this case, how the F5 knows that this a legitimate request and not a port scan ?
well, you need to explicitly add IP addresses of scanning tool in the data group “scannerip” or define in the iRule itself.
