BIG-IP 11.3.0 --> 11.6.0 Upgrade Failover Woes
Hello all,
During an upgrade of 11.3.0 to 11.6.0 I experienced issues when failing over to the standby device to upgrade the active. The devices are in an active-standby configuration, but not configured in an HA-group.
When forcing the traffic group on the active device to standby, the following was initially seen in the ltm log:
Oct 18 21:39:52 LB-F5-1 notice sod[5994]: 010c0044:5: Command:  go standby /Common/traffic-group-1 GUI.
Oct 18 21:39:52 LB-F5-1 notice sod[5994]: 010c0052:5: Standby for traffic group /Common/traffic-group-1.
Oct 18 21:39:52 LB-F5-1 err sod[5994]: 010c0035:3: Function run_external failed to fork at call to failover scripts.
Oct 18 21:39:52 LB-F5-1 notice sod[5994]: 010c0018:5: Standby
Oct 18 21:39:52 LB-F5-1 info tmm[25247]: 01190004:6: Resuming log processing at this invocation; held 32 messages.
Oct 18 21:39:52 LB-F5-1 warning tmm[25247]: 01190004:4: address conflict detected for X.X.X.X (XX:XX:XX:XX:XX:XX) on vlan $$$
Oct 18 21:39:53 LB-F5-1 warning tmm[25247]: 01190004:4: address conflict detected for X.X.X.X (XX:XX:XX:XX:XX:XX) on vlan $$$
Oct 18 21:39:53 LB-F5-1 info tmm[25247]: 01190004:6: Per-invocation log rate exceeded; throttling.
Oct 18 21:39:54 LB-F5-1 notice tmm1[25248]: 01010029:5: Clock advanced by 124 ticks
Oct 18 21:39:54 LB-F5-1 notice tmm[25247]: 01010029:5: Clock advanced by 136 ticks
Oct 18 21:40:13 LB-F5-1 notice logger: /usr/bin/tmipsecd --tmmcount 4  ==> /usr/bin/bigstart stop racoon
This resulted in a situation where both devices flipped back and forth from active to standby.
What I’m most intrigued about here is the following portion of the above snippet:
Can anyone shed some light on this error, and what it’s implications might be?
Thanks! Chris
Why are they not in a HA group?
They are not in an HA group because there are only two, and this wouldn’t fit into our use-case for them.
How did you get out of the loop? “tmsh run /sys failover offline” on the old active?
I forced the (presumably now active) LB back to standby through the web management interface.
So you aborted the upgrade after upgrading the standby to v11.6.0? Did you have mac masquerade configured? I have had some similar but different experience with failover recently, with some services failing to go over to the other device after a fail-back operation.
It was all a bit chaotic, to be perfectly honest. I eventually was able to successfully fail over to the upgraded 11.6 standby unit. I then upgraded the 11.3 unit to 11.6 successfully. After which I failed back to the primary unit, and this happened again but I was unable to recover from it. I eventually booted the standby device back to 11.3 while it was in an active state and it returned to normal. I understand that my panic could very well have been some of the cause for this, but that log snippet is from immediately after I forced a failover. I did not have mac masquerade configured.
Understandably, as nothing is more disturbing and reduces my life more than seeing a loop at an upgrade! How was your HA configured? With a dedicated VLAN? With a multicast addr? You could have put the standby offline and trouble-shoot the HA.
>You could have put the standby offline and trouble-shoot the HA. Yes, this makes worlds of sense now. Again, panic. HA is not configured, essentially. The two devices are not in a configured HA group. Before I failed over the active unit, I unchecked the “Auto Failback” option in the traffic group. Pardon me if I’m misinterpreting your question.
You don’t have to configure an HA group, but you must have HA configured in order to have an active/standby setup, for example, failover/configsync addresses. See 404 Page not found | BIG-IP Documentation .
Ah, yes, sorry. Device failover is *not* configured with a multicast address. It is configured on a dedicated VLAN. The Primary Local Mirror address is on the same VLAN, and the Secondary Local Mirror address is a separate VLAN.
When we upgrade, we put our HA standby device “Offline” before starting the upgrade. This way the active device will not try and failover during the upgrade and when the standby device comes back up, it will be “Offline” until it is checked out for proper config.
