i have routing license , i cannot find option to configure BGP from GUI . is it mandatory from CLI ?
I believe it is, using the imish for the real configuration and the zebos command to control the services.You can use the Configuration Utility (GUI) to specify RPs for a Route Domain but that’s about it I’m afraid.
Thanks , what do u mean by : " control the services" ?
I mean enable or disable/start or stop each different routing protocol, e.g.;
zebos disable ospf Disable the OSPF module
zebos enable bgp Enable the BGP module
is it mandatory from CLI ?i think so.
as Steve mentioned, you have to enable routing protocol before configuring.
sol8261: Enabling a dynamic routing protocol (9.x - 11.1.0)
sol13802: Enabling dynamic routing protocols for a route domain
Thanks , now i found the steps to enable & Configure BGP , one more question :
at the below solution it is shown how to configure route map to filter advertised BGP routes , but i want to make sure that F5 will Rx no routes from Router ( Filter incoming ) , how to do it ?
Sorry SSHSSH, I’m afraid I don’t know. Can I suggest you take a look at the following ZebOS command reference for BGP: 404 Page not found | BIG-IP Documentation
Thanks alot
You’re welcome. If you find it’s possible, perhaps you can provide a brief rundown of how it’s done for the benefit of others?
