Hello,
I’m not struggling with setting up BGP between Cisco ARS routers and LTM Viprion4800 between two vrf’s Internet and Public Access but rather with the redistribution…
neighbor 1.2.3.4 remote-as 12345
neighbor 1.2.3.4 description Public Acesss
neighbor 1.2.3.4 advertisement-interval 0
neighbor 1.2.3.4 default-originate
neighbor 1.2.3.4 soft-reconfiguration inbound
neighbor 1.2.3.4 route-map accept-inbound-Public Access in
neighbor 1.2.3.4 route-map accept-outbound-Public Access out
neighbor 4.3.2.1 remote-as 12345
neighbor 4.3.2.1 description NLHRL1PE01-IA
neighbor 4.3.2.1 advertisement-interval 0
neighbor 4.3.2.1 soft-reconfiguration inbound
neighbor 4.3.2.1 route-map accept-default-route in
neighbor 4.3.2.1 route-map accept-outbound-TCIA out
This is done on the both LTM nodes, the active and the standby, so by using default-originate, the two Cisco routers in vrf Public Access gate receive two different default gateways…
*> 0.0.0.0/0 1.2.3.4 0 65423 i
and
*> 0.0.0.0/0 1.2.3.5 0 65423 i
This cannot be good ?! So how can we make a difference between the two routes to the LTM active/standby members?
If we do AS-prepend=1 on LTM node1 and AS-prepend=5 on LTM node2,
in case of issues and a failover of LTM takes place, the BGP is still advertised with AS-prepend=5 and BGP shortest path leads to the standby member with AS-prepend=1
How can we overcome this routing scenario ?
