I have added BGP to routing domain 0 on the BIG-IP GUI using the AWS cloud BIG-IP. however i cannot find out where to add my routing peers.
imish does not work tmsh does not work zebos does not work
Where do i specify the routing neighbors?
admin@(ip-1 )(cfg-sync Standalone)(Active)(/Common)(tmos) zebos enable bgp === Protocols are no longer enabled or disabled with === === this utility. Please use tmsh, gui or icontrol. ===
usage: zebos [-r
admin@(ip-1 )(cfg-sync Standalone)(Active)(/Common)(tmos) imish Dynamic routing is not enabled in route domain 0 admin@(ip-1 )(cfg-sync Standalone)(Active)(/Common)(tmos) imish ? admin@(ip-1 )(cfg-sync Standalone)(Active)(/Common)(tmos) tmsh ? Syntax Error: unexpected argument “tmsh” admin@(ip-1 )(cfg-sync Standalone)(Active)(/Common)(tmos) tmsh Syntax Error: unexpected argument “tmsh” admin@(ip-1 )(cfg-sync Standalone)(Active)(/Common)(tmos)
