Better view over loggs from F5 - add-on splunk
Hi!
Im looking for a add-on to splunk that will help me troubleshoot APM proxy services and more generally view and understand loggs from BigIP F5
Currently the F5 is running on 12.1.2.
Br
//Bixo
Hi Bixo
I’m not an APM engineer myself so I have asked 2 colleagues from Engineering team at F5 who works with APM and the answer was the following:
  • Create a pool
    • I think Splunk listen on port 514 for all log details
    • on BIG-IQ you would do this on port 9997
  • Create destination
    • Create high speed destination
    • Use high speed log destination to create another destination this time a syslog
  • Create Publisher
    • Use syslog destination to create Publisher
  • Associate Publisher with access log profile
    • Need to navigate to access log and modify [ kind of following this article here: myF5 ]
  • Associate log profile with access profile
The 2nd Engineer pointed this document for you: Logging and Reporting
Hope it helps,
Rodrigo
Thank you for the answer. Will give it a try.
Br
//Bixo
Hello, there are also some APM/Splunk templates available:
