Best way to list poolmembers
Hi, i have this code that gets a list of pools, then uses “Get-F5.LTMPoolMember” to get a list of poolmembers. The output looks like this:
Pool         : /blablabla_pool
Address      : 10.80.15.xxx
Port         : 0
Availability : AVAILABILITY_STATUS_GREEN
Enabled      : ENABLED_STATUS_ENABLED
Status       : Pool member is available
Pool         : /blablabla2_pool
Address      : 10.80.7.xxx
Port         : 0
My problem is that it takes almost 1,5 minute to generate the list, so i’m guessing that there’s something wrong with my code. That part of the code looks like this:
function Get-Pools()
        (Get-F5.iControl).LocalLBPool.get_list();
  $pools = Get-Pools
  $poolmembers = foreach($pool in $pools) { Get-F5.LTMPoolMember -Pool $pool }
  $poolmembers
Would appreciate some help!
Hi Conny!
You can actually fetch an array of pools at the same time which reduces overhead alot.
Something like this:
if ( (Get-PSSnapin | Where-Object { $_.Name -eq "iControlSnapIn"}) -eq $null ){
    Add-PSSnapIn iControlSnapIn
$user = 'myuser'
$pass = 'mypassword'
$success = Initialize-F5.iControl -Username $user -Password $pass -HostName 1.1.1.1
$f5 = Get-F5.iControl
$PoolList = $f5.LocalLBPool.get_list()
$ActionServiceDown = $f5.LocalLBPool.get_action_on_service_down($PoolList)
$LBMethod = $f5.LocalLBPool.get_lb_method($PoolList)
for($i=0;$i -lt ($PoolList.Count);$i++){
    Pool Name
    $PoolList[$i]
    Action on service down
    $ActionServiceDown[$i]
    Load balancing method
    $LBMethod[$i]
/Patrik
Hi, Thanks! Sorry for the late reply. I can see that your code runs faster, but i don’t know how to use it to get the same output as i get with $poolmembers = foreach($pool in $pools) { Get-F5.LTMPoolMember -Pool $pool }
In many of the examples they use 2D-arrays. Is that the only way to do it? Because that is to advanced for me :slightly_smiling_face:
Are you using some kind of framework or custom functions? I am not sure that “Get-F5.LTMPoolMember -Pool $pool” actually exists as a command.
What exactly do you want to do?
/Patrik
Hi, this is complete code:
Add-pssnapin iControlSnapIn
Initialize-F5.iControl -HostName myhost -Username myuser -Password mypass
$ic = Get-F5.iControl
$ic.ManagementPartition.set_active_partition('mypartition')
$pools = Get-F5.LTMPool | Select -ExpandProperty Name
$poolmembers | Where-Object {$_.Availability -eq 'AVAILABILITY_STATUS_RED' }
Hi!
To be honest I did not know that this method existed and I could not find it in the API. However, if all you want is to speed it up I replicated the result in a function below.
Untested on v10 though. Let me know if you encounter issues.
Initialize Snapin
Add a custom class with properties matching the object you got before
Add-Type @'
public class Member
    public string Pool;
    public string Address;
    public string Port;
    public string Name;
    public string Availability;
    public string Enabled;
    public string Status;
Function Get-Pool-Members {
    Param([string]$BigIP, [string]$User, [string]$Password, [string]$Partition="Common")
    Declare variables
    $ObjMembers = @()
    $NodeDict = @{}
    Connect to the BigIP
    $Success = Initialize-F5.iControl -HostName $BigIP -Username $User -Password $Password
    Get an iControl Handle
    $F5 = Get-F5.iControl
    Change Partition
    $F5.ManagementPartition.set_active_partition($Partition)
    Get Pool Lists, statuses, nodes etc
    $Poolmembers = $f5.LocalLBPool.get_member_v2($PoolList)
    $PoolMemberstatuses = $F5.LocalLBPool.get_member_object_status($PoolList, $Poolmembers)
    $NodeList = $F5.LocalLBNodeAddressV2.get_list()
    $NodeIPList = $f5.LocalLBNodeAddressV2.get_address($NodeList)
    Save the nodes in a dictionary for convenient access
    for($i=0;$i -lt ($NodeList.Count);$i++){
        $NodeDict.Add($NodeList[$i], $NodeIPList[$i])
        for($x=0;$x -lt ($PoolMembers[$i].Count);$x++){
            Create a new temporary object of the member class
            $objTempMember = New-Object Member
            Populate the object
            $objTempMember.Pool = $PoolList[$i]
            $objTempMember.name = $PoolMembers[$i][$x].address
            $objTempMember.Address = $NodeDict[$objTempMember.name]
            $objTempMember.Port = $PoolMembers[$i][$x].port
            $objTempMember.Availability = $PoolMemberstatuses[$i][$x].availability_status
            $objTempMember.Enabled = $PoolMemberstatuses[$i][$x].enabled_status
            $objTempMember.Status = $PoolMemberstatuses[$i][$x].status_description
            Add the object to a list
            $ObjMembers += $objTempMember
    Return the object list
    Return $ObjMembers
$poolmembers = Get-Pool-Members -BigIP "10.0.0.1" -User "myuser" -Password "mypassword" -Partition "Common"
/Patrik
Hi Patrik, That’s awesome. Thanks!! Really appreciate this.
Inga problem! Let me know if you run into any issues. :slight_smile: /Patrik
