Hi, I would like to ask what you would recomend as a test system for the BIG-IP F5 system. What I would like to be able to do 1. Simulate 3600 series, if possible. 2. It should be able to simulate failover 3. only LTM is needed, as we do not use any other features at the moment.
You can get a BIG-IP Virtual Edition Lab License now for around $100, this includes all modules but is capped at 10Mbps throughput and if you buy two licenses and install two BIG-IPs in your hypervisor of choice you can set them up in a HA Pair. Failover would be network only, not hardware.
