best practice for ssl ciphers
hi everyone
we’ve recently had a security audit and the report has recommended that we disable the following ciphers:
EXP-DES-CBC-SHA
EXP-RC2-CBC-MD5
EXP-RC4-MD5
EXP1024-DES-CBC-SHA
EXP1024-RC4-SHA
DES-CBC-SHA
i know how to disable them but i don’t know how it will effect the end users. i’m concerned that by disabling all of the above i might accidentally prevent internet explorer 6 (random example) from working
can anyone offer any assistance? has anyone done it before?
thanks
Hi Skuba,
One of our banking customers decided on using the following based on penetration and browser testing:
tmm --clientciphers 'HIGH:!SSLv2:!ADH'
      ID SUITE                          BITS  PROT  METHOD CIPHER MAC    KEYX
  0:  53 AES256-SHA                      256  SSL3  Native AES    SHA    RSA
  1:  53 AES256-SHA                      256  TLS1  Native AES    SHA    RSA
  2:  55 DH-RSA-AES256-SHA               256  SSL3  Compat AES    SHA    DH/RSA
  3:  55 DH-RSA-AES256-SHA               256  TLS1  Compat AES    SHA    DH/RSA
  4:  57 DHE-RSA-AES256-SHA              256  SSL3  Compat AES    SHA    EDH/RSA
  5:  57 DHE-RSA-AES256-SHA              256  TLS1  Compat AES    SHA    EDH/RSA
Any client that doesn’t support one of these ciphers would get a TCP reset. In practice, I don’t think the customer has received any complaints from clients who are unable to access the VIPs.
Another option is to use an iRule to enforce high ciphers but give clients who don’t support a high enough cipher an HTTP response indicating why they can’t access the site. You can do this following a codeshare example:
http://devcentral.f5.com/wiki/default.aspx/iRules/RedirectOnWeakEncryption.html
Aaron
One thing to note: explicitly setting ciphers can affect the BigIP’s ability to offload to hardware, which means you could potentially take a CPU hit. Here are some solutions for you to reference. It also may be worth confirming with support on this for the most recent info.
Cipher Overviews (basically a bunch of links to other solutions of value for SSL):
Fully accelerated Ciphers:
-Matt
Agreed… good point. The handshake for ciphers listed as native in the tmm --clientciphers command will be accelerated in hardware and be more efficient.
Aaron
thanks for all the information, but i’m still a little confused as to how this change will actually effect our users. for example, if i disable EXP-DES-CBC-SHA what web browser will this actually impact? etc
cheers
If you disable a cipher in the client SSL profile, LTM won’t offer it in the list of available ciphers in the server hello during the SSL handshake. There wouldn’t be any negative impact if the client and LTM can agree on a cipher. The only problem arises if there isn’t at least one cipher in the list of ciphers the client and LTM both support. In that case, the SSL handshake will fail.
So it’s good to configure the limited ciphers on a test VIP and test with each OS/browser combination (or as many as you can) that your web app supports.
Aaron
Aaron
Hi Aaron
Thanks again for your response. You’ve hit the nail on the head there - I’ve been asked to disable the ciphers mentioned previously ASAP, and I don’t know what it will effect (i.e. what combinations of OS/browsers)
I know this sounds lazy, but I would have thought someone would have produced a list online (not on DevCentral, but I was hoping someone would have a link to a site that says “Cipher A works fine with Windows XP/IE6” etc)
But I guess not as someone would have posted the link. Looks like it’s going to take a while to test this out fully
Thanks for your help
With the 2011-09-23 news of the following:
“BEAST attacks algorithms that use a mode known as cipher block chaining (CBC), in which information from a previously encrypted block of data is used to encode the next block. AES and DES, two strong cryptographic algorithms used to secure network and Web traffic, both use CBC. The RC4 cipher does not.”
there is concern that we need to re-order our preferred cipher list and possibly eliminate certain ciphers from our list of supported ciphers.
I’ve read the below links and wondered if anyone knows of any “F5 responses” to the latest threats … like “here is how to handle this if you are worried about it”.
Researchers Claim Attack Tool Can Crack Encrypted Web Traffic
http://www.eweek.com/c/a/Security/Researchers-Claim-Attack-Tool-Can-Crack-Encrypted-Web-Traffic-222593/?kc=rss
New Attack Breaks Confidentiality Model of SSL, Allows Theft of Encrypted Cookies
http://threatpost.com/en\_us/blogs/new-attack-breaks-confidentiality-model-ssl-allows-theft-encrypted-cookies-091611
sol8802: Using SSL ciphers with BIG-IP Client SSL and Server SSL profiles
sol11444: SSL ciphers supported on BIG-IP platforms in version 10.x
sol10262: SSL ciphers used in the default SSL profiles in BIG-IP version 10.x
sol6739: SSL ciphers that are fully hardware accelerated on BIG-IP platforms
sol7815: Configuring the cipher strength for SSL profiles
sol11631: SSL ciphers used in the clientssl-insecure-compatible and serverssl-insecure-compatible SSL profiles
SSL Profiles Part 4: Cipher Suites
http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/1086418/SSL-Profiles-Part-4-Cipher-Suites.aspx
Best practice for ssl ciphers
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/52/aft/1168042/showtab/groupforums/Default.aspx
