Best method to programmatically create iApps on F5 Big-IP appliance?
I have used pycontrol2 to write some helper scripts calling the iControl API to create pools and virtual servers. I have now been asked to investigate the possibility of creating iApps in a similar fashion. I’ve looked at the Big-IQ API documentation and the wiki on this site, but am not finding an answer (possibly I am looking in the wrong place). Does anyone have any pointers for me?
Hello Michael, lets agree on a baseline : you don’t want to create Iapps with Icontrol, you want to use Icontrol to deploy an Iapp template ?
if yes you need to have a look to the Management.ApplicationServiceBinding.
Here is an example for http iapp minimal information requested, REST is you friend here if you can :
my_soapui_iapp
         /Common/f5.http
                  net__server_mode
                  lan
                  basic__port
                  80
                  pool__addr
                  10.100.42.13
                  net__client_mode
                  wan
                  client__http_compression
                  /Common/httpcompression
                  pool__http
                  /create_new
                  pool__pool_to_use
                  /create_new
                  pool__port
                  80
                  monitor__monitor
                  http
                  pool__hosts
                     name
                        www.toto.com
                  pool__members
                     addr
                     connection_limit
                     port
                     port_secure
                     priority
                     ratio
                        172.16.20.2
                        0
                        80
                        443
                        0
                        1
Thanks, Arnaud; that clarifies things.
