I’m new to iRule and BIGIP and we’re using this box to terminate specific SSL connections (for credit cards equipments). Everything just works fine except I’d like to know :
1/ Why a connection was refused for some reasons.
2/ Who has terminated the SSL connection (which IP), because we’re going to aggregtate thousands of connections and tcpdump is not appropriate.
3/ If possible : check the packet content after decryption.
I’ve search on the forum but still not found something useful so far.
But I use HTTP only for testing purpose. When setup will be complete I will have to monitor SSL connections only.
Second problem : As far as I known logging to local0.* is written in /etc/var/tmm. We’ll have thousand of connections going to that bigip and I wouldn’t like to have not enough disk space. Instead I use a remote syslog server with this part of code inside syslog-ng.conf :
Send messages to localhost through udp port 514
destination d_remoteLogTunnel {
udp (“x.x.x.x” port (514));
Performing logging
log {
source (local);
filter (f_catchall);
destination (d_remoteLogTunnel);
How can I send connections logging only to remote server ?
In the syslog-ng.conf you can specify in your filter which events you want logged to which destination (local or remote) using ‘match’ and ‘not match’.
Take a look at this post from Tungstent as well as the overall thread for some additional info: (Click here).
I’ve managed to setup logging for successful connections.
How about the failed connections ? As far as I known there is no event in iRules which could trigger an event when for example a SSL connection has failed ? (As a reminder I use a speciic TCP protocol, no HTTP here).
