Bea Weblogic persistence
We are using bigip with Weblogic cluster. Since session is replicated only on 2 nodes, we had to find a solution that knew the additional server where the original session was replicated and if the primary node was down the irule had to switch over to the second node. I finally found a solotion that seems to work.
Any ideas how to improve/change it?
when RULE_INIT {
array set ::nodelist { }
array unset ::nodelist
when CLIENT_ACCEPTED {
set insert_wls_headers 1
set reselect 0
set retries 0
set node1 “”
set node2 “”
set lastServer “”
set request [HTTP::request]
set uri [HTTP::uri]
set hostname [HTTP::header host]
if { $insert_wls_headers } {
HTTP::header insert WL-Proxy-SSL false
HTTP::header insert WL-PATH-PREPEND test
HTTP::header insert WL-Proxy-Client-IP [IP::client_addr]
HTTP::header insert Proxy-Client-IP [IP::client_addr]
HTTP::header insert X-WebLogic-Request-ClusterInfo true
set insert_wls_headers 0
switch -regexp $uri {
mainservlet {
set jss [findstr [HTTP::uri] “jsessionid” 11 “?”]
set jsess [getfield $jss “!” 1]
set jvmid1 [getfield $jss “!” 2]
set jvmid2 [getfield $jss “!” 3]
if { [ info exists ::nodelist($jvmid1) ] } {
set node1 $::nodelist($jvmid1)
if { [ info exists ::nodelist($jvmid2) ] } {
set node2 $::nodelist($jvmid2)
if { “$node1” != “” &&
[LB::status pool prelive_wls_pool member $node1 7001] != “down” &&
“$lastServer” != “$node1” && $reselect < 2 && $retries < 2 } {
} elseif { “$node2” != “” &&
[LB::status pool prelive_wls_pool member $node2 7001] != “down” &&
“$lastServer” != “$node2” && $reselect < 2 && $retries < 2 } {
} default {
pool prelive_wls_static_pool
when LB_FAILED {
LB::down
if { [matchclass $uri starts_with $::servlets] } {
set lastServer [LB::server addr]
incr reselect
if { [LB::server addr] == “” || $reselect > [active_members prelive_wls_pool ] } {
reject
return
LB::reselect pool prelive_wls_pool
if { “$lastServer” == “$node1” && “$node2” != “” && $reselect < 2 &&
[LB::status pool prelive_wls_pool member $node2 7001] != “down” } {
pool [LB::server pool] member $node2 7001
} elseif { “$lastServer” == “$node2” && “$node1” != “” && $reselect < 2 &&
[LB::status pool prelive_wls_pool member $node1 7001] != “down” } {
pool [LB::server pool] member $node1 7001
when HTTP_RESPONSE {
if { [HTTP::header exists “X-WebLogic-Cluster-List”] }{
set server_mappings [split [HTTP::header “X-WebLogic-Cluster-List”] “|” ]
HTTP::header remove “X-WebLogic-Cluster-List”
foreach servermap $server_mappings {
set jvmid [getfield $servermap “!” 1]
set ipp [getfield $servermap “!” 2]
set ip1 [expr {($ipp >> 24) & 0xff}]
set ip2 [expr {($ipp >> 16) & 0xff}]
set ip3 [expr {($ipp >> 8) & 0xff}]
set ip4 [expr {$ipp & 0xff}]
if { [ info exists ::nodelist($jvmid) ] } {
log “jvmid: $jvmid; ip: $ip1.$ip2.$ip3.$ip4”
set ::nodelist([getfield $servermap “!” 1]) “$ip1.$ip2.$ip3.$ip4”
switch -regexp [HTTP::status] {
50[0-3]$ {
LB::down
LB::detach
incr retries
if {$retries < 3 && [ info exists ::nodelist($jvmid2) ] } {
log “WARNING: $host retrying $retries”
HTTP::retry $request
If LB_FAILED or http errors direct the user to the mainservlet :
else {
if { $reselect > 1 || $retries > 1 } {
HTTP::uri “/test/mainservlet”
Yes, but with regex its simple, for example:
^/(files|lib|js|img|test|..)/(?!(.*)(servlet1|servlet2).*$) {
pool1
} default {
pool2
This irule should work fine, tested with wl8
when RULE_INIT {
set reselect 0
set retries 0
set node1 “”
set node2 “”
set lastServer “”
set uri [HTTP::uri]
mainservlet {
}elseif { [ info exists ::nodelist($jvmid2) ] } {
} default {
when LB_FAILED {
LB::down
incr reselect
reject
return
5 0 [ 0 - 3 ]$ {
LB::down
LB::detach
incr retries
nice, thanks for the post.
I’ve been noodling with this idea off & on for the last year without an environment to test in, looks like you may have nailed it.
Regarding optimization:
You probably want to take a look at this article Colin recently wrote about polymorphic operators (Click here) and replace some of them with the appropriate string operators where ever string-only comparisons take place.
And I agree with Colin on eliminating the regex ops as much as possible. While it seems like a trivial choice, (especially if you are as comfortable with regex as you obviously are), the cost of firing up the regex engine is apparently obscenely expensive in comparison with the alternatives, especially the iRules native comparison operators, so you might consider using them in place of your 2 “switch -regex’s”
I’d replace:
         mainservlet {
with
switch -glob $uri {
         *mainservlet* {
only if you need to match multiple URI’s.
Otherwise use the even more efficient
if { $uri contains "mainservlet"} {
for a single test like this.
I’d also replace:
         50[0-3]$ {
with
if { [HTTP::status] starts_with "50"} {
HTH
/deb
corrected some syntax, but still looks like
5 0 [ 0 - 3 ]
(less the spaces)
Is being replaced with
5 0 Ύ - 3 ]
(less the spaces)
/deb
Hello? If exist node3 ?
