HI All,
I am new to F5 technology, kindly help me with some basic documents for LTM & GTM.
I looked into the stuffs in Devcentral, but to be frank not sure where to start with bit confused.
Thanks in advance!!! Srish
HI All,
I strongly recommend university.f5.com you’ll find under “Product and Solution Training” a course for LTM v11.4 and another one for v10 but which is worth a look
they are not really meant for study, but the product pages also provide a bunch of information
once you select your version you get a number of useful document such as implementation guides
for example, for GTM 11.6
