Internal servers are 192.168.2.0
self Ip 192.168.2.254 virtual ip 192.168.2.200
Clients are in 10.0.2.0/24
Clients can reach the network 192.168.2.0
What is the use of external ip here ?
Do we still require to set the static route
You probably don’t need one - you appear to be using using a one-armed configuration.
Almost certainly - you will want traffic from your virtual to return to the clients via the gateway that routes between 10.0.2.0/24 and 192.168.2.0/24
