Hi I have a BigIP 3600 running TMOS 9.4.5. My setup is like this:
One Virtual server, standard tcp with an HTTP profile (modified only to add a fallback url) A oneconnect profile added to the virtual with the source mask changed to 255.255.255.255. Everything else is default A Universal persistence profile attached to an IRule with the following:
when HTTP_REQUEST { if { [HTTP::cookie exists “__appname”] } { persist uie [HTTP::cookie “__appname”] } } when HTTP_RESPONSE { if { [HTTP::cookie exists “__appname”] } { persist add uie [HTTP::cookie “__appname”] } }
A pool with 3 servers, using ratio member with each server having a ratio of 1 (round robin essentially)
The scenario: We keep 2 of the 3 servers in the pool at all times (the other is forced offline as a hot spare). During a release or issue with one of the other 2 servers, we will bring the third server online. During normal operation, servers A and B get ~5500 connections (because the default on oneconnect is 10K).
The problem: When we bring server C in and take server A out, we expect to see the BigIP balance the connections between B and C “evenly” (within an acceptable margin). What we actually see if server B gets 11K+ connections and server C hovers around 50.
Anyone know why this is and what, if anything can be done to force the balance. If you need more information, please let me know.
TIA
