Background color and device name on BIG-IP device on webgui after we login to device highlighting to which device we have logged in.
It should remain permanently when after upgrade.
Hi F5-Geek,
Configure Advisory Banner using the GUI
To access this feature in 11.6+ navigate to System > Preferences, change your view to advanced and scroll to the bottom of the screen and you will see an Advisory Section.
Credit goes to @Robert Teller 74374, see Easter Egg: BIG-IP Advisory Banner - DevCentral for more details.
For versions prior to 11.6 use the command below:
tmsh modify sys db ui.advisory.color {value “<red | orange | yellow | green>”}
tmsh modify sys db ui.advisory.text {value “TEXT GOES HERE”}
