b interface show [[ data format ]]
hi all,
do you know how to get my LTM interfaces statistics in unformatted data format.
output of
“b interface show”
is displayed in M(ega) or G(iga).
But i want the statistics in unformatted data format.
do you know how I can display the unformatted statistics for the interfaces ?
with the GUI, it is possible to display the interfaces statistics by
selecting [unformatted] for [Data Format]
thank you,
I’ve never seen or heard of a way to disable the normalization of the counts in any of the bigpipe commands. Perhaps you could check with F5 Support on this. If you do find a method please reply as this has been a problem in the past.
Thanks,
Aaron
hi,
yeah, I think you open a case at F5 support for that.
by the way,do you know where the original statistics data reside on the BIG-IP ?
I guess the bigpipe command or the GUI pools the network interfaces couts or statistics from a directory on the (BIG-IP 1500 version 9.3.x)in order to display them.
I wonder is there any way to have access to the raw data ?some sort of directory like /var/rrd.
thanks.
