Azure F5 BEST VM
I deployed a f5 BEST VM in azure, i can connect to SSH and can ping it also, but cannot connect to its GUI page. i am using Ip address
Can anyone help urgently?
Make sure your security group is allowing 443. 443 is needed to connect to the GUI.
If you are on a single NIC config, you will have to connect to port 8443 instead of 443.
HERE is some more info.
Hope that helps! If it does please up-vote and select this answer, it’d be greatly appreciated!
-Dylan
