I have an F5 instance that was configured last month. After configuration things seemed to be working fine.
We have finally gotten around to using it, and found it locked up only displaying “Configuration Utility restarting” in the GUI.
In the logs, this is the closest I’ve come to something useful:
Jan 25 08:49:07 ip-10-177-32-196 err tmsh[8700]: 01420006:3: Loading configuration process failed. Jan 25 08:49:07 ip-10-177-32-196 emerg load_config_files: “/usr/bin/tmsh -n -g load sys config partitions all” - failed. -- 0107146f:3: Self-device unicast source address cannot reference the non-existent Self IP (10.177.32.196); Create it in the /Common folder first. Unexpected Error: Loading configuration process failed. Jan 25 08:49:07 ip-10-177-32-196 err mcpd[5700]: 01070425:3: Full configuration load failed.
Not certain where to go from here and could use some troubleshooting assistance.
