Hello,
I can’t seem to find information on how long the AVR database keeps the collected statistics.
Is there a way to control the size of the DB?
Regards
Hello,
Regards
Hi Steve,
An answer here that’s a bit outdated, I suggest you to raise a ticket to f5 support in order to check if this information is still up to date.
Regards
Thank you Lidev for the information!
You’re welcome steve.
If my answer was helpful, please don’t forget to mark as “Select as Best” in order to pass your post as resolved and help other people to find it ![]()
