Automatically upload SSL Certificates
Is there a way to automate the upload of SSL certificates to the BigIP via iControl or the new Python SDK?
We have a load of certificates which will need to be uploaded and an automated way would be preferable.
Assigning the SSL cert to the VS would also be helpful
Thanks,
DF
Hello,
You can use the following icontrol uri :
/mgmt/tm/ltm/profile/clientSsl to create or modify a clientssl profile and assign a certificate
/mgmt/tm/sys/file/sslCert to create or modify a certificate
You can also launch tmsh commands like this :
create ssl-cert [name]
modify ssl-cert [name]
app-service [[string] | none]
source-path [URL]
