Automated F5 LTM pre and post checks
Hi
I’m trying to automate F5 check using F5sdk, unfortunately I think that sdk retrieve virtual server details via .conf file.
Reason I’m telling that is from sdk I’m unable to retrieve F5 Availability.
Below is the script I’m using to print virtual server names,
from f5.bigip import ManagementRoot
# Connect to the BigIP
hostname = input("Please Enter F5 IP: ")
mgmt = ManagementRoot(hostname, "admin", "admin")
# Get a list of all pools on the BigIP and print their names and Availability
virtuals = mgmt.tm.ltm.virtuals.get_collection()
for virtuals in virtuals:
   print(virtuals.name, virtuals.partition)
Anyone know how can I get availability status using F5 sdk ?
Hello Thanushka.
Try this →
devices = session.tm.cm.devices.get_collection()
for device in devices:
	print("Device: {}".format(device.name))
	print("State: {}".format(device.failoverState))
Output:
Device: bigip1.mydomain.local
State: active
Device: bigip2.mydomain.local
State: standby
KR,
Dario.
Hi Dario
Thanks for the responses, but this will return device HA status not the virtual server (Availability). status..
for virtual in virtuals:
    if hasattr(virtual, 'subPath'):
        subp = virtual.subPath
    else:
        subp = ""
    if (subp != ""):
        print("Name: '%s' AvailabilityState: '%s'" % (virtual.name, get_vs_state(virtual.name, subp)))
    else:
        print("Name: '%s' AvailabilityState: '%s'" % (virtual.name, get_vs_state(virtual.name, "")))
The availability of a virtual server resides in the stats
from f5.utils.responses.handlers import Stats
session = ManagementRoot("F5_mgmt_IP","username","password",token=True)
virtual = session.tm.ltm.virtuals.virtual.load(name='testVS')
#https://<F5_mgmt_IP>/mgmt/tm/ltm/virtual/testVS
virtualstats = Stats(virtual.stats.load())
#https://<F5_mgmt_IP>/mgmt/tm/ltm/virtual/testVS/stats
for key, value in virtualstats.stat.items():
    if value.get('description') != None:
        print("{}: {}".format(key, value.get('description')))
    elif value.get('value') != None:
        print("{}: {}".format(key, value.get('value')))
KR,
Dario.
