auto-sync timing
hi guys,
had deployed v11.1 on 2x 6900 configured auto-sync for the sync-only device group.
maunal sync is working fine, just a query.
what is the interval time that need to wait from a config change to the auto-sync kick in?
appreciate any help given :smiley:
cheers
Hi Henry,
I’d guess that the sync would be triggered any time a config change is made. What are you seeing?
Aaron
i have configure it as follow
i have 2 device group configured.
1 group sync-only with auto sync enabled
1 group sync-failover
manual sync is ok no issue. however when i do any changes, i check the status for sync-only group it says 2 device are consistent but yet the changes i made hasn’t been sync over and the top left status is still pending changes.
cheers
I am seeing same issue on 11.2.1 guest setup in active active HA . Anyone come up with an answer for this issue.
however when i do any changes, i check the status for sync-only group it says 2 device are consistent but yet the changes i made hasn’t been sync over and the top left status is still pending changes.what object did you change? it was *not* failover object (object which floats between unit when failover), is it?
Sync-Only
A Sync-Only device group contains devices that synchronize configuration data, such as policy data, but do not synchronize failover objects. A maximum of 32 devices is supported in a Sync-Only device group.Manual Chapter: Understanding Device Groups
