Auto populate Edge Portal Bookmark Links
Dear all,
is there a way to push down bookmark links into Edge Portal app instead of every user keying in the address before bookmarking?
Thanks!
you can create webtop links would that work for you? i don’t believe you can influence to local bookmarks from the APM.
I believe showing users a message box would help since I intend to have another HTML page showing all the page links.
