Auto Map & SNAT
Is it possible to have one VS using Auto Map and the second one using SNAT? The idea is to translate client IP address to the floating address if accessing one VS or to the SNAT address if accessing a second VS. I have only one client IP (MQ server) in my design.
The SNAT configuration is setup on each VS, you can have VS1 configured for automap and VS2 configured with a SNAT.
You have 2 VS, so even if you have only one client you establish two separate connection to access each other.
The question is more, are you sure that your backend support to have a client connecting and presenting with 2 IPs ?
Thanks for the replay. I created SNAT Pool List with one IP address and assigned that list to the VS. F5 does the translation but is sending RST to SYN ACK. Client has no problem to see different source IP addresses.
Does it have the right VLANs enabled and listening ? L4 or L7 ? Any other iRules attached to the VS ? Can you provide a rough diagram and IP address along with the VS configuration ?
Did you check Firewall rules or network routing for the IP in the SNAT pool
You can activate logging of tcp reset with the following command : tmsh modify /sys db tm.rstcause.log value enable
