Thank you for all the help! I’ve made some changes and they seem to be working. The Irule will begin by prompting for a client cert. It will complete the request if the cert is valid or redirect to another website if not. You can cancel out of the client cert portion and be prompted for a username and password. The connection will complete if you have valid credentials or redirect to yet another website if you fail. Could someone look this over to see if I am making any rookie mistakes(I am a programming newbie). Thank you in advance.
when CLIENT_ACCEPTED {
set tmm_auth_http_collect_count 0
array set tmm_auth_http_sids {ldap -1}
when CLIENTSSL_CLIENTCERT {
set ssl_cert [SSL::cert 0]
set ssl_errstr [X509::verify_cert_error_string [SSL::verify_result]]
set ssl_stuff [list $ssl_cert $ssl_errstr]
session add ssl [SSL::sessionid] $ssl_stuff 180
set ssl_stuff2 [session lookup ssl [SSL::sessionid]]
set ssl_cert2 [lindex $ssl_stuff2 0]
set ssl_errstr2 [lindex $ssl_stuff2 1]
if { $ssl_stuff2 != “”} {
if { $ssl_errstr2 eq “ok”} {
HTTP::header insert SSLClientCertStatus $ssl_errstr2
HTTP::header insert SSLClientCertValidFrom [X509::not_valid_before $ssl_cert2]
HTTP::header insert SSLClientCertValidUtil [X509::not_valid_after $ssl_cert2]
HTTP::header insert SSLClientCertSubject [X509::subject $ssl_cert2]
HTTP::header insert SSLClientCertIssuer [X509::issuer $ssl_cert2]
if { $ssl_errstr2 != “ok”} {
HTTP::redirect “http://x.x.x.x”
if { $ssl_stuff2 eq “”} {
set tmm_auth_sid $tmm_auth_http_sids(ldap)
if {$tmm_auth_sid == -1} {
set tmm_auth_sid [AUTH::start pam default_ldap]
array set tmm_auth_http_sids [list ldap $tmm_auth_sid]
AUTH::username_credential $tmm_auth_sid [HTTP::username]
AUTH::password_credential $tmm_auth_sid [HTTP::password]
AUTH::authenticate $tmm_auth_sid
if {$tmm_auth_http_collect_count == 0} {
HTTP::collect
set tmm_auth_http_successes 0
incr tmm_auth_http_collect_count
when AUTH_SUCCESS {
if {$tmm_auth_http_sids(ldap) eq [AUTH::last_event_session_id]} {
incr tmm_auth_http_successes
if {[info exists tmm_auth_http_sufficient_successes]} {
if {$tmm_auth_http_successes >=
$tmm_auth_http_sufficient_successes} {
foreach {type sid} [array get tmm_auth_http_sids] {
if {$type ne “ldap” && $sid ne -1} {
AUTH::abort $sid
array set tmm_auth_http_sids [list $type -1]
HTTP::release
incr tmm_auth_http_collect_count -1
HTTP::respond 401
HTTP::release
when AUTH_FAILURE {
if {[llength [array names tmm_auth_http_sids]] > 1} {
HTTP::respond 401
AUTH::abort $sid
HTTP::respond 401
HTTP::respond 302 Location “http://y.y.y.y”
when AUTH_WANTCREDENTIAL {
HTTP::respond 401
AUTH::abort $sid
HTTP::respond 401
HTTP::respond 401
when AUTH_ERROR {
HTTP::respond 401
AUTH::abort $sid
HTTP::respond 401
HTTP::respond 401
Thank you again,
Rob
