Hello,
I am new to scripting iRules and need some assistance in one that i have created. The objective is to direct client traffic based on uri to different pools and then apply persistance at the pool-level instead of the VIP level with version 9.x. The basis of the iRule is that I have create Data List to define the uri instead of having the iRule modify when a uri needs to be add or removed. Data Lists are fastlane_7000, fastlane_7200, fastlane_7300. I create 3 cookies, for cookie insert, fastlane_cookie_7000, fastlane_cookie_7200 and fastlane_cookie_7300. Then I added the following statements to the iRule for cookie persistence at the pool level. I am inquiring if this script would cause any problems that you may know of, I researched on DevCentral and I did not see any reference to problems with this script in other users usage; however, this iRule is very custom. Please let me know your input.
URI Load Balancing for Fastlane Spilt
Objective is to load-balacning FL applications as individual apps across several defined pools
DataList contains variable definition for this iRule
If uri needs to be added please add through Data List
log “The incoming uri is [HTTP::uri]”
if {[HTTP::uri] starts_with “fastlane_7000” or [HTTP::uri] equals “/”} {
pool fastlane_test_7000
persist cookie insert fastlane_cookie_7000 0
log local0. “[IP::client_addr][TCP::client_port]: fastlane_7000 request”
} elseif {[HTTP::uri] starts_with “fastlane_7200”} {
pool fastlane_test_7200
persist cookie insert fastlane_cookie_7200 0
log local0. “[IP::client_addr][TCP::client_port]: fastlane_7200 request”
} elseif {[HTTP::uri] starts_with “fastlane_7300”} {
pool fastlane_test_7300
persist cookie insert fastlane_cookie_7300 0
log local0. “[IP::client_addr][TCP::client_port]: fastlane_7300 request”
else {
