Assistance needed for SNATing plus other irules
I’ve got a task to do some snat and some other traffic modification.
connections with destination-port 6200,6201,6202 should have a timeout of 6 hours.
connections with certain ip (x.y.234.167 and .170) and destination port 1100(openft) should be SNATed to a.b.20.d
now i’ve created following rules
x1
when CLIENT_ACCEPTED {
switch [TCP::client_port] {
6200-
6201-
6202{
IP::idle_timeout 21600
default {
IP::idle_timeout 3600
x2
check if client_addr = any in the class
if { [matchclass [IP::client_addr] equals $::InternalHosts]} {
check if the class contains the server_port requested
if { [matchclass [TCP::local_port] equals $::openft_port]} {
snat using this source address
snat a.b.20.d
don’t do any source address translation
forward
where
class InternalHosts {
host x.y.234.167
host x.y.234.170
class openft_port {
1100
and implemented it to a VS in this order.
virtual Routing_Back {
lasthop pool GW
pool GW
destination any:any
mask none
vlans internal enable
rules x1 x2
profiles int_fastL4
The effect was that new connections couldnt be established.
What mistake have i made?
Any help would be greatly appreciated.
When you say the connection couldn’t be established, what do you see in a tcpdump? Is the connection from the client to the VIP address established? Do you see any serverside packets sent? Is there a RST from the VIP address back to the client and/or a RST sent from the LTM address to the destination? Or does it time out with no response?
If you’re using a fastL4 profile, you’ll need to run tcpdump on the port number to see all packets (tcpdump -ni 1.1 host CLIENT_IP or host DESTINATION_IP).
Also, I think you mean to use TCP::local_port instead of TCP::client_port in the first iRule as I assume you want to check the port the client made the request to--not from.
Can you add logging to each case in the iRules and post anonymized copies of the debug from /var/log/ltm for the failure?
Aaron
