ASM is successfully blocking requests regarding the XSD except for the above
choice
element.
Alarms are available under “Event logs” however for the choice condition, status is always “Legal Request” while we would expect “XML data does not comply with schema or WSDL document”…
*maxOccurs: Optional. Specifies the maximum number of times the choice element can occur in the parent element. The value can be any number >= 0, or if you want to set no limit on the maximum number, use the value “unbounded”. Default value is 1
minOccurs: Optional. Specifies the minimum number of times the choice element can occur in the parent the element. The value can be any number >= 0. Default value is 1*
However, the choice element doesn’t work better if no attributes are specified:
Regarding the w3c standard, we expect below behavior: XML Schema choice element allows only one of the elements contained in thedeclaration to be present within the containing element.
choice
Which is not what we got. SoapUI report the non compliancy, BigIP ASM doesn’t…
