ASM Wildcard parameter no match except *
Hello,
I’m having some trouble creating a manual wildcard parameter that will actually be used by ASM instead of the more general * parameter.
HTTP request POST contains the following:
{“file_ids”:[],“message”:“Some user input”,“channel_id”:“blahblah”…}
ASM violations are triggering on the “message” field in the above string. I’d like to create a parameter for the “message” field so I can address it directly. However, ASM uses the * wildcard parameter regardless of my attempts to create a wildcard parameter for it such as using following:
message":"(.*)","channel_id
message\":\"(.*)\",\"channel_id
"message":"*","channel_id
Any help would be appreciated.
It looks like it’s JSON content. Did you apply a JSON profile to your security policy ?
Bye
Yann
Bye
Yann
Followed the article below and created the JSON profile and associated it with the wildcard parameters but no change in the behavior.
