Hello
Is there a tool to trigger F5 ASM violations and attack signatures.
Hello
Hi Alex,
The answer(s) depend largely on what your goal is. Are you trying to test the policy itself or the alerting for violations?
Aaron
yes i like to test alerting for violations or attacks
You can use the logger command to generate arbitrary syslog messages:
SOL7165: Testing SNMP traps and email alerts
Else, if you want to more thoroughly test, you might need to configure a test policy with all checks enabled, set up some policy definitions and send test HTTP requests which trigger the violations.
Aaron
Hello and thanks for the reply
the question now how do i send test HTTP requests which trigger the violations?
you can use NMAP to scan the F5 Virtual server ,then the asm will generate violations if the virtuals server is configure with application security profile.
