I have a problem which whenever i apply a transparent security policy to my existing VS, it affects the traffic. Knowing that the VS is related to OWA and Outlook Anywhere which created by the iApp. Any clue why tjis strange behavior.
BR Ammar
BR Ammar
Do you have Data guard, Content Profiles or Virus protection activated ?
Moreover, you have several settings that add javascript code to your application. Check on the browser side that you don’t have any javascript errors in the console.
Hi, I only have a “OWA10_XML” as an XML Profile. the AV is not activated nor the Data Guard.
XML profile use a bufferization technique. Try removing the XML profile just for testing and see if your issues still there
I got an official E-mail from F5 TAC team, The BIG-IP ASM system does not currently support RPC over HTTP. Bypassing the BIG-IP ASM system for connections that use RPC over HTTP 404 Page not found | BIG-IP Documentation
