ASM: Traffic learning - Enforce
Hello,
I’m confused about (Manual) Traffic learning in version 12.1.2. The options are only Accept, Delete or Ignore Suggestion.
Specific request is not blocked (Legal request) - Action is: “Set Perform Staging to disabled. …”, so if I Accept Suggestion, Staging will be disabled - which I don’t want. Is there any option to directly set signature to “Enforce” under Traffic Learning Screen, like it was in previous version (11.6.0)?
12.1.2:
11.6.0:
Best regards,
Špela
