ASM to block a specific URI
Hi All,
I have to configure ASM to block a specific URI
/web-admin/admin/
. Can anyone help with this please. I have configured it as disallowed url, no luck. Even I have created an irule and applied it, same result.
any idea?
The irule which I have created look like below.
  set reqBlock 0
  if { ([HTTP::uri] contains "/web-admin/admin")} {
  set reqBlock 1
when ASM_REQUEST_DONE {
  if { $reqBlock == 1} {
    ASM::raise FLOW_TO_OBJ
-Jinshu
Hello,
You can use a Disallowed URL here, as you’re trying - no need for any iRule magic. Did you check your Policy Blocking Settings? Does it have Block checkbox selected for “Illegal URL”? If not, go ahead and select it, apply the policy changes, and you’re done.
