ASM TMOS v13 Unnable to change enforcement mode after create a default policy.
After create a simple policy (default parameters and with no virtual server) using TMOS v13 HF2 I found that I am unnable to change enforcement mode for example to change to transparent. After I change the enforcement readiness period for example from 7 to 5 I found that I am allowed to change the enforcement mode.
Did someone notice that or know why is this behavior?
Regards Ronald
Looks like you have found yet another bug with v13.0 - please raise a support case with F5 (support@) indicating steps to reliably re-produce this issue
