ASM TLS 1.2
ASM TLS 1.2 - Is there an active signature within the ASM to block against TLS downgrade attacks with the ASM? I am unable to find anything signatures in my signature list within the ASM with the string TLS? Would it be titled something other than TLS?
I’m not sure about the ASM signatures but you could disable the protocols and/or ciphers in the ClientSSL profile. https://devcentral.f5.com/articles/ssl-profiles-part-5-ssl-options
