ASM System Error
(Solved with a workaround)
F5 v11.5.1 HF8
Have tried to deprovision/reprovision ASM - no help;
Furthermore, “tmsh save sys conf” works without any problems. The ASM module itself is working.
Error received after issuing the command: “tmsh load sys conf”:
Loading configuration...
  /config/bigip_base.conf
  /config/bigip_user.conf
  /config/bigip.conf
01070710:3: Can't save/checkpoint DB object, class:asm_http_method status:13 - EdbCfgObj.cpp, line 127
Unexpected Error: Loading configuration process failed.
I’ve additionally reset the ASM DB. As a workaround it’s OK for me. 404 Page not found | BIG-IP Documentation
this error message has somehow similarities with sol15963: ConfigSync may fail with an sFlow error message
If you run a cluster I would try the workaround proposed (has myself a few issues with mcpd where the workaround brought something). If still not working, I would advise you to open a support case.
Alex
