We have deployed an ASM Security Policy with specific technology: aspx:
- When reviewing the learning suggestions, there are several suggestions on standard aspx behavior, such as on mouse click, there are $ used by default by aspx to post-back/render data (it appears in learning as suggestion to accept).
- As aspx is already selected, are these false positive shouldn’t already be known as valid by the ASM Security Policy? Is it normal behavior to see these suggestions that are default to aspx?
Regards, Marc
