Hi experts, we have a security policy build using the automatic policy builder. Currently it is showing 47% complete. I was checking if it has any learning suggestions so far, so i went to Ploicy building > Status (automatic) > details. IF i expand the details under each category, lets say the 1st one - HTTP Protocol Compliance, it gives me a list of violations under it and then there`s a “enable” button. when i scroll my mouse on it. it says “accept the tighten rule”. I am wondering what this means? Is it to enforce all these settings?
under all these violations, it states that the loosen: N/A and Tighten: Rule Satisfied.
Tighten simply means adding an explicit entry. In an example where you’ve got a wildcard fine type. You can tighten the policy by adding explicit file types, .CSS .HTML .txt etc. and then remove the wildcard. The policy is now tightened.
I’m not sure about that… This is True for File Types and Parameters, but for HTTP Compliance, and Evasion Techniques detected for example this Enable the settings in the “Blocking Settings” Section. Enabling those settings mean, start blocking non compliant HTTP Requests as soon as you ar in Blocking Mode.
