Dear All,
Is there any possibilities to analyze the ASM Qkview file, if so please share the procedure.
As far as I know , usually we send the ASM Qkview to OEM for their analysis . However I need to verify it on my own.
Please confirm.
With Regards, SK.
this article details how the asm qkview script works :
You can parse logs, view configuration files and sql dump
Hello Yann,Thanks for the reply .. I would like to analyze the qkview using ihealth portal , same like we do for LTM . is it doable ?
Hi, since 10.2.2 and above, the asm debug file can be uploaded to ihealth. You will have an additional menu “Security” where you can view your security policies
You have limited visibility into the ASM policy on ihealth. Heuristics will run, and some basic configuration objects will be visible, but event logs, for instance won’t be visible.
