I have a query related to ASM configuration sync I am running Tmos 11.6 with latest HF. I have LTM configuration running perfectly fine on my units n Sync works completely fine but the ASM configuration is not syncing between the units properly. On active unit I have 8 policies but on secondary it shows only 5 also on active unit there policies r blocked but on secondary same is transparent, how I can’t figure out. Has someone faced similar issue? What could be the possible solution of this?
There was no sync happening between the two units and it was very complicated, the VS were created using the iApp and the HTTP compression is not license was an error showing up later which was causing the boxes not to sync the configuration completely…
