ASM on a separate Device infront of LTM Azure
hi,
A quick question any input would be much helpful !!! I’m working on a design where I would like to know if I could have a separate f5 virtual device just running ASM in transparent bridge mode and then routing traffic to another F5 virtual device running LTM? All this is in Azure!
Is this possible?
Thanks, Prabu
I dont think thats possible because once you configure ASM policy in transparent mode,you need to assign to virtual vip.
If we have ASM and LTM on same Virtul mechine ,its easy to configure.
but why your looking separate device on ASM ?
Thx
Srini
