ASM Manual Security Policy Questions
when Configuring manual security policy i can enter parameters for :
Application Language , i choose it as “unicode-utf” , but after finishing creating the policy i cannot see this parameter ( ie : i want to check the application defined for a manual policy after it has been created ) ?
Which version are you running? I think this has changed over the versions.
Aaron
10.2.3
10.2.3
