ASM Login Page protection for Basic Authentication without failed string
Hello,
Its possible to create and configure an ASM Login Page for Brute Force protection to a system that uses APM Basic Auth (401) and does not send any String for failed/wrong username? According the F5 Documentation on how to create a Login page, its needs to configure a failed string:
A string that should NOT appear in the responseA string that indicates a failed login attempt and prohibits user access to the authenticated URL; for example, Authentication failed.
Ref: Creating Login Pages for Secure Application Access | BIG-IP Documentation
So my question is, its possible to configure APM to send 401 with an failed string, so it can be detected by ASM on Brute Force Login Mitigation?
**For the ASM protection on APM VS, im using the layered Virtual Server configuration.
Hugo Frauches,
What about adding a positive string for when the user successfully logs in? Does APM send back a specific string, http response code etc. when a successful logon happens? You can add this. If the ASM doesn’t see this then it will conclude it’s a failed login.
HTH,
N
