ASM limiting throughput and connections/s
Sorry if this is stupid question but I am not ASM expert. I was looking into docs and can’t see a way to set limit on throughput and connections/s per given subnet. Is there a way to do that using GUI and configuring policy?
Could DoS protection be used for that - seems that there is a way to limit TPS but per given subnet like Subnet/16 mask?
Or only way is to use iRule. Connection limits on virtual as well do not look like being able to limit by subnet.
Piotr
You can do that using the DDoS profiles (just learned that myself). You can also do it in an iRule, but I think the DDoS configuration would be more predictable, efficient and supportable.
It’s pretty flexible. They went over this at the F5 Agility break out (I saw it at a Users Group), and I think that presentation is available online.
Thanks for info. Are you sure you can use it for throughput and/or connections/s per specified source net like 192.168.1.0/24? Can’t see options to specify it like that, so for 192.168.1.0/24 limit to 3Mbps and 100 CPS and for 192.168..2.0/24 to 1Mbps and 50 CPS?
Any hint how this presentation could be named to start searching for?
Piotr
I guess I found all 2015 Agility presentations and labs but can’t find anything directly related to ASM and per subnet throughput or CPS limits :frowning:
Piotr
So just took a look and I don’t see a way to do that natively. Perhaps it’s in v12 (the presentation was using v12, but I don’t remember if it was there or not).
One thing I think you could do, however, is create a DDoS profile and apply that profile via an iRule (sort of a combination). I would keep the IPs you wanna rate limit in a Data Group and do a class match in CLIENT_CONNECT to apply the DDoS profile (https://devcentral.f5.com/wiki/iRules.DOSL7__enable.ashx). That way you are using the efficiency of the DDoS profile with the added functionality I think you are looking for to apply it to particular CIDR’s.
