Hello,
I am building a home LAB to study APM/ASM/GTM, can you suggest what I need to add to the lab to study for the APM/ASM/GTM exams?
Thank you
Hello,
Thank you
The “hackit yourself auction website” may be a good starting point. It’s what they use in instructor-led 4 day ASM training courses. It’s a piece of software with almost no built-in security features. Pretty much any attack against it will work. After you successfully execute an attack, try to find a relevant security-check to patch up the attack vector.
https://devcentral.f5.com/articles/configuring-the-big-ip-and-php-hack-it-yourself-auction-site
Brill, Thanks Hannes will have a look, will I need any AD/RADIUS for the setup?
Remote authentication is completely irrelevant for the ASM traning, but it will come handy once you start experimenting with APM.
