ASM IP Address Exceptions Never Block Not Work
Hello expert,
I set the IP whitelist (Never Block) for the policy to 10.2.36.32 in partition 2.
However, the IP is still blocked by WAF.
Why is this happening?
As I see you policy is already created under DMZ1 partition.
So, to my understanding, you don’t need to use route domain id as it is already seted as default.
Try setting the IP without %2
Hi Former Member​ ,
The reason for the block is that the attack signature was triggered.
@SanYang - If @Injeyan_Kostas helped you solve your problem please consider Mark As Solution to help others find this answer and get help in similar situations.
Thanks,
Lief
