ASM: How to Add Sensitive Parameters to a Policy via TMSH?
I have a list of thousands of sensitive parameters that I need to add to an ASM policy. How would I best automate this? Is there a way to do this via TMSH or via something else?
You can POST the list via REST using the following endpoint:
mgmt/tm/asm/policies/MD5HASH/sensitive-parameters
What version are you working with?
Not too tricky - first off use the iCR Python module and go through the asm/policies//sensitive-parameters endpoint to add the sensitive parameters. There are two ways to retrieve the MD5 hash - use
get_asm_id(name)
or
create_hash(name)
and you can check out the iControl REST User Guide. Chapter 7 is about ASM.
PM me with details if you want more help.
